Play without Wifi waves
If I remove the antenna, xbox series x will work with all cable connections? Rj45 and usb Joipad? I would like to have not waves in my house
좋은 질문 입니까?
좋은 질문 입니까?
Both the controller and the console internet is wifi based. Removing the antenna only reduces its emission, not disable it.
I don't think it is a smart choice to "not have waves", why? Is it based on some myths about radiation and health?
해당 답변은 도움이 되었습니까?
Yes I start in 2009 having strong headache with my first cordless phone (philips) at home e xbox one viewings film and playing with. Turning off both of them the headache went away, then I began to put the antenna away from my home I have all connection on cable now at job and at home so I do for my neighbours, but this happen to me and I don't know why it happen, I only know that I have pain when the wifi waves are starting to close to me, so it's better for me playing and using technology without wifi and bluetooth...
Disconnecting the antennas won’t stop the WIFI emissions. You need to just go into your settings to disable it
How to Disconnect Wi-Fi connection in XBOX Series or XBOX One Console
해당 답변은 도움이 되었습니까?
I fast see the video and I don't have this command in my xbox one S ... so I hope it will be on Xbox series X. I put out one antenna from xbox one s and it is working good the same by rj45. The antenna in front isn't possible to remove then I make a physical stop of it with a stone that absorbs waves and like this i can use my console at home, with the controller with cable usb (when you put the cable in the controller it stop the wifi signal). tsk g
@g.mandatori - As I stated disconnecting the antennas doesn’t change things! The radio signal is still being emanated by the connector point.
I would put it back on as you have created a load issue so overtime the logic will become damaged!
As you don’t have Series X unit you’ll need to look into getting one so you can correctly shutdown the radio.
I have EHS.
After a huge amount of research and help from a techy friend I have managed to remove all wifi and bluetooth from my xbox series x via two internal cards being removed.
I also use a wired controller and Ethernet.
The two links below show the internals of the xbox series x we used in order to strip it down and remove both wifi cards.
However, it is not for the faint hearted and you will need someone that is competent in working with electronics/ electronic repairs in order to do this.
But my xbox now works perfectly fine without these cards and I have no emissions at all.
https://www.youtube.com/watch?v=83uAbW02...
https://www.youtube.com/watch?v=EFAdFprW...
Good luck, you are not mad- this is a serious health thing. I know, I have it too.
해당 답변은 도움이 되었습니까?
Thank you for commenting on this! I have EHS and we bought our 13 year old son the Xbox series S for Christmas and set it up via ethernet thinking it would be fine. Boy was I wrong...my head felt like it was going to pop from the pressure from the RF output. I have a meter and tested it on even a different floor - my son had it hooked up in the basement family room and tested in the kitchen and the levls were through the roof! Might you or anyone have suggestions on how to disable the RF on the Xbox series? I feel bad and really want our son to be able to use it but can't handle the pain it's causing. It's currently at his grammy's down the road so he goes there to play BUT I also don't want him to be exposed either as this effects everyone. We are completely wired at home. Thanks!
24 시간 전: 1
7일 전: 1
30일 전: 6
전체 시간: 119
