주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
20 질문 전체 보기
start iPhone 5 with broken glas
I have moved to a newer iphone. But I have some SMS and photos which have not been backed up on Icloud. Is there any way to start the phone without using the front display so that I can download SMS and photos from the memory in the phone?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 4개
가장 유용한 답변
try 3utools (it's free). if you can get the phone to boot, while connected to your pc, you can pull individual stuff (pictures, videos, etc) directly out of the phone. it can also do whole phone backups (not sure if the backups can be read/restored by itunes)
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Just press the power button and let it boot, then use itunes to make a backup of the iPhone and flash it on your iPhone.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
I started Itunes but it requested that the lock code for the phone is entered. But since the display is damaged and does not work I cannot unlock the phone. Is it possible to get around this problem?
@laxen sadly, that's the only way I know..
댓글 달기
@laxen you can only do that if you don't have any kind of screen lock. If your phone requires you to enter a passcode, you cannot do that without the display.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
very true. and also if the phone wants you to trust the computer.
@beekerc that's right. I forgot about that Trust issue :-) Good point
댓글 달기
Well actually there may be a way - go get a lightning to USB adapter and connect any generic USB keyboard to it - not sure it still works, but well worth a try.
If possible - try connecting that keyboard to a working iPhone and test and if it works - wait for your phone to boot up, blindly enter your passcode and you should be good 👍
P.S.: and actually even without a display you can see what you phone would show if you connect your iPhone to a Mac and run QuickTime to capture iPhone’s screen. Here’s how:
https://support.apple.com/en-gb/guide/qu...
It may be necessary that you have connected your phone to this Mac before and made your iPhone trust this computer- keep that in mind
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
i didn't even know that was possible.
댓글 달기
답변을 추가하세요
Tomas Persson 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 74
