주요 콘텐츠로 건너뛰기
Game Boy는 1989년 4월 21일 일본에서 출시되었고, 1989년 7월 31일에 북미, 그리고 1990년 9월 28일에 끝으로 유럽에서 출시되었습니다. 커다란 회색 케이스와 모델 번호 DMG-01이 특징입니다.
71 질문 전체 보기
Powering on (red led) but absolutely nothing.
Dmg powers up but no activity on the screen and a low white noise, with or without a cartridge. I’ve seen many repair tips regarding a powering up but something visually. Any thought? What can be ruled out and where to begin? Thanks community.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 1개
I have this problem too, I cleaned the contacts with vinegar and then with iso, now it powers on and all you hear is a click coming from the speaker and no sound or picture. I tried headphones and there is just a white noise. I swapped the screen half with a working one and vice versa. The screen half is good and works on my working half with the battery compartment. When I put my good working one in the faulty game it the same thing happens. I’ve cleaned the board with iso, everything looks decent but still no picture or sound. Any ideas?
댓글 달기
답변 1개
선택된 답변
@bradley007 you did not tell us what you already checked. If we make the assumption that there is power on your GB, I would next check components around the display and the power rails. Something like this
and this one
from here should help with the troubleshooting. Also, the beast got a few miles on it, check all the traces and capacitors for corrosion, delamination etc. Post some good pictures of your mainboard etc. with your QUESTION. That way we can see what you see.
기존 질문에 이미지 추가하기
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
Thank you! Will put some pictures uoo ok for reference.
When I turn on my TV I have red and green lines vertically running through it how do I get them to go away so I could watch the screen
shawn dancy what make and model is your Tv? what have you checked? Do you have sound?
댓글 달기
귀하의 답변을 추가하세요
Brad 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 5
7일 전: 10
30일 전: 29
전체 시간: 277
