주요 콘텐츠로 건너뛰기
모델 A1419 / EMC 2806 / Late 2014 또는 Mid 2015. 3.3 또는 3.5 GHz Core i5 또는 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 또는 3.5 GHz Core i5 또는 4.0 GHz Core i7 (iMac17,1) 모두 Retina 5K 화면 장착
Remove the fusion blade SSD necessary w/SATA SSD upgrade?
I have a late 2015 27" retina iMac with the 1tb Fusion drive... including the tiny SSD on the motherboard. I was going to replace the blade SSD, but read about all the issues with the hardware firmware causing sleep-wake issues on this vintage, and decided that was not a good idea. (OWC won't even list their blade drives as compatible with Late 2015s for this reason.) So I'm going to just replace the spinning drive with a Crucial 2TB SATA SSD. I've read people stating on this forum that it's best to pull the old blade drive from the motherboard and discard it in a scenario like this. Why? Can't I just leave the thing unformatted and call it a day? Seems like a bunch of nonsense extra work unless there's an actual technical reason to do this. Any enlightenment would be helpful. Thanks
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
선택된 해법
Short answer: No
You have to break the fusion array on the old hard drive BEFORE you add the SATA ssd, and then you could have both (sata ssd and blade)!
Ask @danj for help breaking the array
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Thank you. As the OEM blade is tiny (24GB), I've decided to go whole hog and replace it with a 1TB WD Black SN850x and Sintech adapter. Fingers crossed that it works flawlessly as others have reported.
댓글 달기
Not all versions of macOS plays nice when you leave it.
Best to pull it, besides the size is quite small. If you want maximum performance I would put in a replacement blade drive instead. But these drives are more expensive Vs the SATA SSD.
이 답변이 도움이 되었나요?
점수 2
댓글 4개:
Yes, but has Apple issued a patch for the boot rom that stops the machine from crashing when it goes to sleep? OWC does not list their blade product as compatible with iMac 17,1 models.
@Chris Cline - I would go with an Apple blade drive on this series.
As far as patches you’ll need to talk to Apple I have no inside knowledge. As I explained different macOS are different as Apple often alters the systems firmware which often involves Fusion Drives.
I did some more research. I decided to go with a 1TB WD Black SN850x and a Sintech M2 NGFF adapter. People seem to be having great results with WD drives on the Late 2015 17,1 EMC 2834 (and Macs in general) with no sleep-wake issues, as long as the EFI firmware is up to date. I'm going to replace the SATA drive with a Crucial 1TB MX500, which I will use as a built-in Time Machine drive. I will report back.
Update: SN850x is working flawlessly in the late 2015 iMac. Read and write speeds of ~3000MB/s. No sleep-wake issues at all. A worthwhile and relatively painless upgrade.
댓글 달기
답변을 추가하세요
Chris Cline 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 11
전체 시간: 592
