주요 콘텐츠로 건너뛰기
MacBook 제품군은 2006년 5월에 처음 소개되었으며 Apple의 가정용 노트북 iBook을 대체하였습니다.
3787 질문 전체 보기
How to power up MacBook without power switch?
My power switch doesn't work but It will take a few weeks before I'll be able get a new one.
I was looking for a way to turn it on from the logic board, until I get the new keyboard, but I couldn't find how to do it on my model.
Can anyone help me here?
Thanks a lot
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 3개
선택된 답변
Be aware that if you power up the machine using the power pads and then connect the top case while the machine is powered you could generate a short that could fry the logic board. Instead use an external keyboard and a mouse until you install the new top case.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Look at the picture in this link. You should be able to short across the 2 solder points and it will start up if in fact the power button is the issue. What color macbook is it i may have one for you?
http://guide-images.ifixit.net/igi/5daVK...
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
the power pin is the leftmost one from the bottom row. you can use the fan surface as the ground
the diagram is attached on the bottom
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Shevcach 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 6
전체 시간: 4,136
