주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2009년 중반기 모델 A1278 / 2.26 or 2.53 GHz Core 2 Duo 프로세서 EMC 2326
Why can't my MacBook boot up
I replaced the battery of my mid 2009 MacBook and the hard drive with a new Solid State Drive. The MacBook, however, would show a folder with a question mark. I haven't replaced the ram but when I did, it wouldn't displace anything. The battery isn't faulty because I have inspected it. This is a serious problem.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Hi
When you see a question mark that means that the mac doesn’t know what to boot from(it also does this if there ISN’T anything to boot from)
If you haven’t reinstalled macOS you will need to do that to fix your issue
Here’s a guide in doing that
https://support.apple.com/en-gb/guide/ma...
If you already have macOS installed I suggest you reseat the cable going to the SSD:-)
Hopefully this helps
Any questions please ask
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Was the system ever patched? If so see my thread "Cannot access boot utilities - greyed out EFI Boot - SOLVED!" hopefully that helps someone!
댓글 달기
답변을 추가하세요
Neon Knight 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 30
전체 시간: 366
