주요 콘텐츠로 건너뛰기
The Dyson V6 Absolute is a cordless, bagless cleaner released in September 2014, with HEPA filtration that captures allergens. Used for all floor types and weighs 5 pounds. Identified by model number SV09.
19 질문 전체 보기
Why after charging and after using Max function it stops?
Dyson V6 (SV05).
I charge the Dyson. If I start it using the max button it stops in less than a minute. Then I plug it and press the button for 20secs as advised in this group and with the MAX function it stops working fast but if I turn the MAX off it works for a while? Do I need to change the battery? They are quite expensive. Thanks for your help
Carla
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
It sounds like a weak battery. The Max function is powerful so it pulls more amps, which reduces the voltage the battery sends to the motor. Not enough voltage stops the motor. Probably the regular ( non Max) stay above the minimum voltage so it stays running.
This battery repair can help you.
Dyson v6 Absolute Battery Pack Replacement
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Thanks a lot for your answer. The instructions are great. The problem is batteries are so expensive. But at least I know why it is happening. Regards. Carla
댓글 달기
귀하의 답변을 추가하세요
Carla 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 19
전체 시간: 110
