주요 콘텐츠로 건너뛰기
첫 번째 iPhone 모델, Model A1203은 4, 8, 또는 16GB 용량과 알루미늄 뒷면을 가지고 있습니다. 수리를 하려면 상당한 양의 비집기와 납땜을 요구할 수 있습니다.
Help! iPhone stuck in boot loop with weird shadowing on screen
im planning on replacing the display, just need to find a part with a digitizer and lcd with all the small parts
it only turns on when its plugged in as shown in the video, and has a weird shadowy affect after it turns itself off.
anyone know what to do?
ive tried putting in in dfu mode while its doing this,hard resetting also, and it doesn't help
is this also a display issue/recovery issue or is it something else?
I GOT TO GO INTO RECOVERY MODEEEEE
okay but is it compatible with the newest itunes update?
what do i need to do to actually recover this phone?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
are you concerned about data on the phone?
if not, then i'd recommend downloading 3utools and installing it on your PC. put the phone into DFU mode (you will need to google how to do this for your model), connect it to your PC and execute a anti-recovery Flash.
this will install the latest firmware and IOS for your phone.
this usually works for me when i get bootlooping phones to evaluate - but only if the data is expendable.
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
@beekerc
is there a version for mac?
also i don't mind the data, i bought this phone off ebay to repair
also the phone turns off before i can put in dfu i only can barely get recovery mode to work in time before it shuts off it only stays on for about 10 seconds before turning off:(
@timtomissus
no. 3utools is for pc only, sorry
댓글 달기
답변을 추가하세요
timtom77 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 4
전체 시간: 265
