이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 3개:
This is one of those jobs where the pictures aren’t high enough quality I’m afraid. Also one where a microscope is really needed. I see one trace going to the vias plus what looks like a burn between the two. also if it’s a multi layer board then more connections could be shorted or damaged. Something has blown causing that damage. It’s possible it might be un repairable.
[deleted] 의
@hasbanshakil consider cleaning your board of all the soldier and burn residue. Then repost some good clear straight-on pictures of the damaged area.
oldturkey03 의
Can you make me an alternate of its print lines like jumpers
Hasban ur Rehman 의
