Why is my mic not really works?
My mic dosn't work really well. Callers unable to hear my voice clearly
좋은 질문 입니까?
좋은 질문 입니까?
Can you be heard OK when using the phone in the "loudspeaker" (hands free) mode?
If so is the phone in a protective case at all?
If it is remove it from the case and check if you can be heard OK when on a "normal" type call.
If you can now be heard then perhaps the case was covering the voice inlet hole on the bottom edge of the phone.
If you still can't be heard or if the phone wasn't in a protective case, then perhaps there may be fluff or lint blocking the voice inlet hole. Use a vacuum cleaner to try and clear it. Do not use a pin or probe to try and clear it as you may damage the microphone which is directly behind the hole.
If still no good start the phone in safe mode and check if you can be heard when on a call. If you can then a downloaded app is the cause of the problem. The trick is to find out which one. You will need to uninstall each downloaded app, one by one and test the phone in "normal mode" between each uninstall to find out whether it now works OK or not. When it does then the last downloaded app that was uninstalled was the culprit. A downloaded app is one that you downloaded and installed on the phone and wasn't pre-installed on the phone when you first got it.
If still no good, you may have to try a factory reset and if still no good after that it's a hardware problem.
해당 답변은 도움이 되었습니까?
24 시간 전: 11
7일 전: 64
30일 전: 277
전체 시간: 2,772
