주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
2264 질문 전체 보기
What is the type of double side tape
Hi everyone!
I'm looking for the kind of double-sided tape on the gold part on the back of the Lightning connector. I think that golden part needs to somehow stay in contact with the housing.
Does anyone know what type of tape is used?
Thanks in advance.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
Once fitted the loud speaker will hold it down so I wouldn’t worry about it.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thanks for the answer. But unfortunately, part of the tape doesn't stick anymore and the iPhone stopped working the speaker and doesn't charge anymore.
I bought another piece.
댓글 달기
Hi sidneijunior,
I was in the same position with an iPhone X I was working on; I felt like there was probably a reason for the conductive adhesive used on the lighting connector flex, so I went looking for a replacement as well.
I didn't really find any sort of double-sided tape like you're describing, so I ended up with a liquid conductive adhesive that came in syringes. I just squeezed out a little bit and spread it over the area of the flex that was originally glued. Seemed to work; so far so good!
Amazon.com: 5 pieces 0.3ML Silver Conductive Wire Glue Paste For Electronics Repair Applications : Industrial & Scientific
해당 답변은 도움이 되었습니까?
점수 1
댓글 4개:
Thank you for the answer!
I bought another piece, but I solved part of the problem using aluminum foil, the speaker doesn't work, but the iPhone back to charge again.
It’s not the adhesive it’s either your speaker or you need a new charge port assembly. I have removed loads of ports and transplanted them into other phones with no issues.
@sidneijunior, when you say you bought another piece, what exactly are you referring to? I'm with Nigel in believing you probably need a new lightning port assembly since that's the common point between charging and the speaker.
How exactly did you fix the charging problem with aluminum foil? I'm curious...
@dadibrokeit I bought the whole set that I sent in the photo, in the parts that have the stickers, I made some folds with the aluminum foil with the exact size, so the iPhone started charging again.
댓글 달기
귀하의 답변을 추가하세요
sidneijunior 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 64
