Power indicator light is on , battery light is orange . I have to scre
I have no power but when I press the power button the indicator light comes on but nothing happens.
좋은 질문 입니까?
좋은 질문 입니까?
Try a full power refresh in case it is a corrupted BIOS and check if that resolves the problem.
Here’s the procedure:
a). Disconnect the charger from the laptop if connected.
b). Remove the main battery from the laptop.
c). Open the laptop and remove the RTC battery from the motherboard.
Here’s a teardown video for the laptop that will help. The RTC battery is seen being removed at 5:47 minutes into the video.
When the battery is removed measure its voltage. If it is <2.6V DC replace it. The battery model number should be printed on the battery. Mostly it is a CR2032 which is commonly available everywhere e.g. supermarkets
d). Press and hold the laptop's Power button for a full 30 seconds and then release it.
e.) Reinsert the RTC battery (or its replacement). (usually it is +ve on top as marked on the battery)
f). Reverse the above from Step c). to re-assemble the laptop.
f.) When the laptop is completely re-assembled, connect the charger and try to turn on the laptop.
If it starts OK there may be a message about the date and time being incorrect. This is normal as the BIOS has been completely reset back to its default settings. Once the date and time have been adjusted the message won’t appear the next time that the laptop is started.
If you had previously changed any user defined settings in BIOS to suit whatever specific hardware configuration that you had for the laptop, then these will have to be set again.
해당 답변은 도움이 되었습니까?
24 시간 전: 1
7일 전: 1
30일 전: 14
전체 시간: 88
