주요 콘텐츠로 건너뛰기
How can I install a wifi adapter?
How can I install a wifi adapter for my HP 256 G4
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 3개
가장 유용한 답변
Hi @esakesak
Have you checked the status of the WLAN network adapter in Device Manager > Network Adapters i.e. not installed correctly (yellow exclamation mark), disabled (red cross) or not listed at all?
If there's no appearance in Device Manager, check if the WLAN adapter has been enabled in BIOS.
If there's no WLAN enable/disable setting in BIOS check if the WLAN module is missing from the laptop.
Here's the maintenance and service guide for the laptop. Go to p.44 to view the procedure to remove/replace the WLAN module.
If there's none there or if perhaps it is faulty at the top of the page you'll find the model numbers of the 3 WLAN adapters compatible with the laptop. Two have Bluetooth capability as well as WiFi and one doesn't so be aware of that if you need a replacement. Search online using the part number only to find suppliers that suit you best.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Typically wifi adapter drivers are installed automatically depending on your operating system. Many WiFi adapters can be installed through the USB ports on your laptop, like these.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Well you can try the following:
  1. Download the updated driver and extract it.
  2. Right click on Computer Icon, and then click Manage.
  3. Open Device Manager.
  4. Click Browse my computer for driver software
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Esakesak 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 5
전체 시간: 113
