주요 콘텐츠로 건너뛰기
모델 A1013, A1052, A1085, 또는 A1107 / 1440x900 스크린 해상도
Boots from battery, not from power cord
I rescued the machine in question from being tossed in a dumpster. It will power up if I charge its battery in my own 17" PowerBook first. But it will not start up without the battery when I plug the power cord in, nor will it charge the battery. The power adapter I tried is the original that came with my (identical model) 17" PowerBook. I'm thinking the DC-in board needs replacing.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
That is what I would recommend trying first.
댓글 달기
답변 3개
선택된 해법
That's a very good guess. I'd do it.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
I concur with the others here, this is the part you need.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
The DC/In Board is a good place to start, but what power adapter do you have? is it a 65W or a 45W, if it's a 45W, the PowerBook can only charge off of it, and not actually run, the 65W can run, and charge at the same time.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
The adapter is 65W. It came with my 17" PowerBook G4 1.67 GHz low-res, which is the exact same as the one that I salvaged. The salvaged PowerBook neither powers up nor charges with the power adapter. Nothing happens at all. Only an externally-charged battery brings it to life. Which, frankly, surprised me.
You could check the connections to the DC-In board, and if that doesn't work, your best bet would be to replace it, if that doesn't do it, then the logic board, or battery might be defective.
댓글 달기
답변을 추가하세요
fletcherism 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 7
전체 시간: 2,142
