Replacement of Different emc board
I have MACBOOK AIR A1466 EMC 2925 whose logic board is damaged ( ic burnt ).
Will Logic Board EMC 3178 work on it, if I replace it? Please check the image
좋은 질문 입니까?
좋은 질문 입니까?
The best way to check if a logic board is compatible is to locate the boards number 820-00165-A. Here we can see both the original and the replacement boards are the same, so it’s a direct drop in.
Reference the guide here to do the task MacBook Air 13" Early 2015 Logic Board Replacement
I do see iFixit has the same board available at a similar price MacBook Air 13" (2017) 1.8 GHz Logic Board do consider the warranty.
해당 답변은 도움이 되었습니까?
Hi Dan Thanks for your answer.
@claudiawassmer - If you’re all set, don’t forget to score the answer and accept it. Thanks 🙏
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 45
