주요 콘텐츠로 건너뛰기
While Seiko makes many watches, some of the straps and bands are adjustable and can be adjusted or repaired when broken.
2 질문 전체 보기
Tool to open expensive watch It's a Seiko.
Which tool do you recommend for prying open my classic wristwatch to replace the battery. Watch shops charge too much for this simple task. It's a Seiko.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
Hi @joelsilverman
If the back of the watch has notches, here's a video that may help.
If it has what is known as a snap off back then this video may help.
Update (03/30/23)
Hi @joelsilverman
I think that the only two that may have a chance (depends on the size of the gap between the cover and the watch frame) would be these
Jimmy
iFixit Opening Tool
Handy tool for opening electronics. 이미지
제품
Jimmy
$7.95
Plastic tools designed to get you in the tightest cracks, without damaging your treasured devices. 이미지
제품
iFixit Opening Tool
이 답변이 도움이 되었나요?
점수 4
댓글 1개:
Thanks. It's the snap-off type. Which tool does iFixit offer that would work?
댓글 달기
Watchmaking has long history and tradition that it should be considered its own category, with specialized toolset and skillset.
What you are looking for is case openers that are made specifically for the type of cases your watch has, be it a clip-on or screw-back cases.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Joel Silverman 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 9
전체 시간: 364
