주요 콘텐츠로 건너뛰기
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
20 질문 전체 보기
Would using a higher rated power lead cause issues?
I'm not sure if I worded the title correctly but I don't know what else to call it specifically. The PSU I have is "rated" (I'm not sure that's the right term for it though) for 200-240V 6A. The only leads I have are either 250V 5A or 250V 10A. Would using either of these cause issues for my PC?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
In this case, you should use the 250V 10A power cord. You can go the same or up on voltage and amperage.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Hi @danielg60938
Might depend on where you are.
Using the 5A cable might not damage the PSU but may damage the cable or it becomes a fire hazard.
If the local mains power supply is 240V and the PSU is rated for 200-240 6A then a 5A cable is not sufficient. The cable will run hot if the full amount of current is required.
The maximum power that a 240 6A PSU can accept and use is 1440W whereas the 250V 5A cable maximum power rating is 1250W
The PSU may not require this amount but you don't know.
I would use the 10A cable to be safe. Let the fuse in the PSU protect it if necessary and don't use the 5A cable as a fuse.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Daniel G 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 55
