주요 콘텐츠로 건너뛰기
2020년 3월에 출시된 인텔 프로세서가 탑재된 MacBook Air 모델 A2179의 2020년 리프레시 수리 및 분해 정보입니다.
103 질문 전체 보기
Fire damages MacBook Air A2337
MacBook Air has fire damaged screen (partially) and dead keyboard/trackpad. No backup :-(
Machine boots using power button to user login which is visible on damaged screen but no way to go any further.
Can I force connect using a bluetooth keyboard and mouse.
Can I force sharing or other connection to other Mac without keyboard or mouse?
Can I remove hard drive install in an external case and use sharing or other to boot from or connect to hard drive?
Tony
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개:
add photos of the damage please! it helps us see what you see to properly diagnose your issue 기존 질문에 이미지 추가하기
have you tried a wired mouse and keyboard?
good idea, I'll try that then post photos
댓글 달기
답변 1개
You should be able to access the data using a wired external keyboard and target disk mode. Connect a wired keyboard to the system using one of the USB-C ports, then power on the computer while holding the T key on the wired keyboard. Continue to hold the key until you see the Thunderbolt icon appear on the screen. You can then connect a Thunderbolt cable to the damaged computer and to a working computer, and the internal drive of the damaged computer should show up as an attached external drive on the working computer. You can find more info here.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
tonydevito 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 32
