주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nintendo Switch Joy-Con 컨트롤러의 수리 안내서와 정보.
Joy Con not functioning when physically attached to Switch
The Switch was dropped, I replaced the right red joy con’s rail. It now functions fine when wireless, but will not work when physically attached to the switch. The Switch shows the attach animation, when it is attached, but then fails to recognize it and does not accept any input from the joy con.
I then replaced the rail on the actual console, and I get the same error. I have deleted and re-paired the joy cons, and rebooted the switch, and joy con, and still have the same issue. All connections on the joy con have been detached and reseated, and I think have the same issue.
Any thoughts?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개:
do you have an extra joycon or switch you can use for testing?
댓글 달기
답변 1개
Hello! Since the Switch console can recognize a joycon being attached, I think this is an issue with the controller instead of the Switch. There is a connector on the bottom of the rail on the side of the joycon that I think might send button inputs to the Switch. If the joycon looks fine, make sure the ribbon cable on the Switch console’s rail is fine and that it is plugged in all the way.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Steven Boughton 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 9
지난 30일: 30
전체 시간: 3,835
