주요 콘텐츠로 건너뛰기
A2115 / 2019 / 프로세서 3.0GHz 6코어 i5부터 최대 3.6GHz 8코어 i9까지. 2019년 3월 19일 출시.
131 질문 전체 보기
Stuck one Apple Logo without status bar
Hi
The imac turned off one day. Currently it only boots to Apple logo, then restarts, the logo appears again, then screen goes black. I can't get into disk selection or Apple Diagnostics.
Replacing the ram, hard drive (both HDD and flash), power supply does not help.
What could be the reason?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
Try using an Apple USB keyboard to get to the onboard diagnostics. Press the D key as soon as the screen flickers to get to diags. Let us know what you get.
해당 답변은 도움이 되었습니까?
점수 0
댓글 5개:
I already tried that, no change, all the time stuck on logo.
Hi. Is there any update on this case? I do have similar problems here.
@mahew2 - Sadly this sounds like a logic board issue.
@mahew2 if you have wired keyboard, did you try reset NVRAM or hold ALT key to see if you have option to boot from another device ?
Thanky @roboscrap & @danj. Unfortunately, no keyboard command is working on boot. iMac is already disassembled and logicboard is going to be inspected. Since @hubertpudelek seemed to have exactly the same symptoms, it's likely a similar cause – therefore the question if there were any new findings.
Oh, and btw: All 4 LED's on the motherboard are lighting up.
댓글 달기
귀하의 답변을 추가하세요
Hubert Pudełek 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 9
전체 시간: 73
