주요 콘텐츠로 건너뛰기
The Dell Inspiron 15R 5520 laptop features a 14.88" screen, brushed aluminum finish and features a i5 core processor .
12 질문 전체 보기
شاشة الجهاز سوداء ويصدر اربع صفارات
عند تشغيل اللابتوب تضاء لوحة المفاتيح ولكن الشاشه سوداء ويصدر اربع صفارات
Google translate:
The screen of the device is black and it emits four beeps
When the laptop is turned on, the keyboard lights up, but the screen is black and four beeps are issued
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Hi @nbyllaamry
A 4 beep error code is a memory problem.
Try reseating the memory module(s) i.e. remove/reinsert the module(s) and check if that resolves the problem.
Here's the owner manual for the laptop. Go to p.19 to view the procedure to remove/replace the memory module(s).
If still no good, if the laptop has 2 memory modules try using only 1 at a time in case one module is faulty.
If it only has one memory module installed you will have to get another compatible memory module and try it. The laptop uses 1600MHz DDR3 SODIMM memory
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
نبيل العامري 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 7
전체 시간: 281
