How to change bulb in the headlamp
How to change the headlamp
좋은 질문입니까?
ann, here are the steps from the service manual:
1. Disconnect negative battery cable.
2. Disconnect electrical connector from headlight assembly.
3. Remove back cover by pushing in on cover, then rotating cover counterclockwise to disengage from
headlight assembly.
CAUTION: The headlight bulb is filled with a gas which is under pressure.
Damage to glass part of bulb can cause bulb to explode causing
possible personal injury.
4. Pull socket with bulb straight back and remove it from headlight and combination light assembly.
5. If bulb has failed, place it in new bulb carton and dispose of properly.
6. Hold replacement bulb by base, or use clean cloth or paper to avoid touching glass, and install bulb in
socket.
7. Align slots on bulb with corresponding bosses on headlight assembly. Insert bulb into headlight and
8. Install back cover to hold bulb in place.
9. Connect electrical connector.
10. Connect negative battery cable.
Hope this helps, good luck
이 답변이 도움이 되었나요?
Much too vague, completely useless. Anyone could have written this because it lacks any meaningful details. Not even a single picture. Why even bother to write this, it's not going to do anything to help.
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 10,940
