주요 콘텐츠로 건너뛰기
The MSI GS63VR 7RF Stealth Pro is a gaming laptop made by the company MSI in 2017. This page includes repair guides for the GS63VR 7RF-252US-BB7770H16G1T0DX10MH. Model Number: MS-16K2.
My pc is running but nothing shows!
Hello everyone,
My MSI GS63VR STEALTH PRO was running normaly when suddenly crached and the blue screen appeared .. after analysing, it restarts and the same thing happened againg .. after some attempts, the screen would stop at the logo (MSI) until i force it to turn off and stops again at the logo if i turn it back on.
I tried to enter the BIOS by clicking on F3 but than when the screen turned black and never turned on after
I tested the RAM, the HDD and the SSD, tried to link it via HDMI to my TV but nothing appears.
What possibly can bee problem ? What should i do ?
Im desperat 😞
Mise à jour (04/09/23)
Come on some on please help 🥺
Update (04/08/23)
The fan starts running .. the keyboard lights up but nothing shows on the screen
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
@lotfilati so what do you have right now when you turn it on? What exactly happens when you do that?
댓글 달기
답변 1개
선택된 해법
Hi @lotfilatli
Try a full power refresh and check if that resolves the problem
  • Turn off the laptop if it is on and disconnect the charger if it is connected.
  • Open the laptop and disconnect and remove the main battery from the laptop.
  • Disconnect the RTC coin cell battery from the motherboard
Here's an image showing the RTC battery, taken from this teardown video for the laptop. Here's the ifixit MSI GS63VR 7RF Stealth Pro Battery Replacement guide that may also help.
When the RTC coin cell battery is removed, measure its voltage. If it is <2.5V DC replace it. The part number information should be on the battery.
(click on image)
  • Press and hold the laptop's Power button for a full 30 seconds and then release it.
  • Reconnect and replace the RTC coin cell battery (or its replacement), reconnect and replace the main battery, reassemble the laptop, connect the charger and check if the laptop turns on OK
If it turns on OK there may be a message about the date and time being incorrect. This is normal as the BIOS has been reset. Once the date and time have been adjusted, the message won't appear the next time the laptop is turned on. Also if any user definable settings in BIOS have been changed to suit whatever your operating requirement are, they will have to be changed back again.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Lotfi latli 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 15
전체 시간: 379
