주요 콘텐츠로 건너뛰기
The HTC Desire is the first smartphone of the Desire series developed by HTC.
37 질문 전체 보기
White lines on a black screen and no damage to phone?
Desire screen just stopped working. Can only get a black screen with white lines. Taken battery out , put back in --same. Is my lcd gone ????
Phone looks like brand new.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 3개
But what if your battery don't come out
yes what if my battery does not come out
I found out that due to the usage of the phone the foam pad in the back of the LCD flex cable tends to shrink a little and the battery's weight tends to push the flex cable out of the main board socket. I added some clear tape by rolling it up to make it thick, and stick on back sides, and place it on top of that foam pad.
댓글 달기
답변 6개
선택된 답변
could be. http://www.formymobile.co.uk/desiredisas... will help you to get to the screen to check connection or replace
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
This might be more use:
http://androidforums.com/desire-support-...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I solved this problem few times by completely opening my HTC Desire Z mobile phone and then reassembling it. Third time, I noticed that the problem is due to looseness of two, out of three, tiny screws at the "camera" button of the mobile set. Therefore, mobile set was not properly pressed and sealed at the "Camera" button and due to some protection by HTC, screen went black. Now I have used new relatively long tiny screws and the problem is solved permanently.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
i had this problem to but mine was becus of preassure damage!
Are you having your phone in your back pocket?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Heat can damage the screen and cause pixels to malfunction
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Display bord‌‌‌>chack capacitor> hot air
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Doug 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 15
전체 시간: 22,077
