주요 콘텐츠로 건너뛰기
Kodak EasyShare DX7590 Camera
camera not turning on when charged, battery is stuck inside
basically, this sat on a charger for two days, and i had checked it every once and a while
i don't think this was used after about 2016-2015ish?
i tried to remove the batt, but its like stuck inside of the camera (im assuming by corrosion, as it sat in a basement for 8 years or so)
help?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
@timtomissus "his sat on a charger for two days" most likely a dead battery. Take a pair of hemostats or similar and try to pull it out, or you could pour some high-grade isopropyl alcohol into the battery holder and see if that releases it. At this point, most of the damage will already have been done. Use something like this teardown Kodak EasyShare DX7590 Teardown - iFixit to disassemble it and see what is going on.
이 답변이 도움이 되었나요?
점수 0
댓글 3개:
@oldturkey03 also i should mention that its charging dock doesn't work either, the light doesn't light up, but i think some deoxIT should fix that, as its really dusty lol
@timtomissus maybe it's not working since it is not recognizing a battery? Cleaning will definitely be a good start :-)
댓글 달기
답변을 추가하세요
timtom77 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 14
전체 시간: 345
