주요 콘텐츠로 건너뛰기
ASUS TUF Gaming FX505DY. This is a 15.6-inch mid-range gaming laptop with a RGB-backlit full keyboard and number pad.
1 질문 전체 보기
My keyboard is lighted but nothing else works full reset do
Tried reset no power light nothing on screen, no fans charger ok 19 volts. Absolutely nothing but back-lit keyboard tried multiple resets per asus instructions not old and battery was good for hours
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @rogerr32550
Try a full power refresh in case it is a corrupted BIOS and check if that resolves the problem.
Here’s the procedure:
a). Disconnect the charger from the laptop if connected.
b). Disconnect the main battery from the motherboard.
c). Remove the RTC coin cell battery from the motherboard.
Here’s a disassembly video for the laptop that may help.
When the RTC battery is removed measure its voltage. If it is <2.6V DC replace it. The part number is on the battery. If it is a CR2032 then this is commonly available most everywhere e.g. supermarkets.
d). Press and hold the laptop's Power button for a full 30 seconds and then release it
e.) Reinsert the RTC battery (or its replacement - +ve on top as marked on the battery)
f). Reverse the above from Step.b) to re-assemble the laptop.
When the laptop is completely re-assembled, connect the charger and try to turn on the laptop.
If it starts OK there may be a message about the date and time being incorrect. This is normal as the BIOS has been completely reset back to its default settings. Once the date and time have been adjusted the message won’t appear the next time that the laptop is started.
If you had previously changed any user defined settings in BIOS to suit whatever specific hardware configuration that you had for the laptop, then these will have to be set again.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
RogerR 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 5
30일 전: 7
전체 시간: 66
