Wont power on at all after battery change
I was using the laptop one day and then it just suddenly shut off and would not come back on. I changed the battery and it still will not power on. Need some help on what the problem could be.
좋은 질문 입니까?
좋은 질문 입니까?
Hi Walla. I have come across a similar issue with 2 Lenovo Ideapads in the last 2 weeks. Remove the installed ram stick and the laptop should turn on. It is either the ram that has gone bad or the ram slot itself. With the 2 laptops that i dealt with, one was the ram slot that had gone bad and the other the black metal shield that was screwed over the ram. When i removed this shield the laptop powered up fine.
해당 답변은 도움이 되었습니까?
24 시간 전: 1
7일 전: 1
30일 전: 21
전체 시간: 207
댓글 2개
Hi @walla52779,
Does the laptop indicate that the battery is charging when the charger is connected?
jayeff 의
No. There is no charging light indicator when plugged in
Walla 의
