What is the correct fuse?
What is the correct fuse to replace the old, that is burned.
Thanks
좋은 질문 입니까?
Thanks
좋은 질문 입니까?
If you changed the fuse three times and it burns out, you have a short circuit and/or overload in your system. The fuse is doing its job by protecting your circuits.
해당 답변은 도움이 되었습니까?
Look at the fuse side you will see how much the Amp on it and should the volt will be 110v-120v
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 757
댓글 2개
What is the speed of your machine so I know which one you have?
mayer 의
I change the fuse, in 3 times it burned, in other time nothing happening...
Renan Andrade 의
