주요 콘텐츠로 건너뛰기
The N95 8GB is a revision of the N95, with a larger screen, 8GB of internal flash storage and larger capacity battery.
2 질문 전체 보기
질문 마감됨
I can not turn on my nokia n95 8gb phone?
The screen shows the charging battery icon, the number keys lite up when pressed, battery has been charging for several hours, and does not show a full charge. The phone has been dorment for a long time, and im charging it through the usb adapter.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 4개
가장 유용한 답변
Joe, if your phone was not used for a good while, I would suggest that you change your battery. It is possible that you battery is past the point of its life expectancy and not accepting a charge. Good Luck
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
joe ur granda ma must have eat the batterey
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
my nokia n95 is power on after month but it is no power how iam on my mobile self
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
you should use 12 voltage of any charger to shock the battery of n95 for 8 second because i think it was just drain... if u have more problim you can call me baby,,, 09098016760
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 4,263
