주요 콘텐츠로 건너뛰기
Nintendo's upgraded version of the Nintendo 3DS. It features bigger screens, longer battery life, better pixel density, and a better design.
What is the best way to extract stripped screws?
i tried to remove the back shell but last time i screwed the back shell i screwed the screws too much and when i tried to remove the cover again one of the screws go striped pretty bad (the other screw doesn't work I'm not sure if the plastic is worn out or that the screw got snapped)
p.s my pen doesn't stay properly in the shell so it falls out almost every time i pickup my 3ds is it the plastic in the 3ds or the plastic on the pen that is worn out
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Assuming you're familiar with the rubber band method, replace the rubber band with a thin piece of fabric. It works wonders for me, but if it's not as effective for you, check out this guide
As for the stylus, you can see it much better than we can, so that's up to you to determine. If you're taking the 3ds apart anyway, it'll be easy to check the stylus slot for wear, otherwise you can try shining a light into the slot and checking it that way.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
peanut boi 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 4
전체 시간: 68
