Jeep Cherokee 87 won't start
1987 Jeep Cherokee Limited four-wheel drive won't start turns over gets fuel has new coil parked it after work went out in the morning wouldn't start ran day before
좋은 질문입니까?
좋은 질문입니까?
Rutor,
This almost certainly has to do with your coil or coil wires just based on your description of it happening after a rainfall. Since you just replaced the coil, let’s assume that is good. So, I’d suggest buying a new set of plug wires and the wire that goes from the coil to the distributor (if it is separate…sorry i don’t know this engine by heart). Or, the wire that feeds the coil (12VDC) might be shorting out. Best of luck.
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 10
지난 30일: 23
전체 시간: 322
댓글 1개
@rutor1 did you check for spark on all cylinders? What else did you check?
oldturkey03 의
