Why does my tire pressure sign keeps coming on
Why does my tire pressure sign keep coming on
좋은 질문 입니까?
좋은 질문 입니까?
@yeabsragloyg of course you have made sure that your tire pressure is correct in all tires (including spare tire). Check the pressures according to the specs. There should usually be a list of tire pressures for your Camry on a sticker in the door frame.
If you have done all that, you could consider resetting the system. Since you did not give us the exact year for your Camry, use the information from this site
If even a reset does not work, you may need to have your TPMS sensors checked. Any good tire shop can assist you with that.
해당 답변은 도움이 되었습니까?
Yep, yep, yep, 100% agree with @oldturkey03.
Ran into same problem on my son's Cadillac Deville, basically turned out the batteries in the tire sensors had finally given up after 10 years. Note that the non-replaceable batteries in those sensors are only rated for 5 years, so it's fairly likely your batteries have died. Unfortunately they don't make those replaceable, so you end up having to replace all four tire sensors to get the system running again.
@dadibrokeit government subsidized planned obsolescence :-))
Lifespan about 7 years then they all need to be changed for a minimum of ~$500 sensors/labor. Cost of driving I suppose. ;-)
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 72
