주요 콘텐츠로 건너뛰기
iMac은 Apple의 올인원 데스크탑 컴퓨터 라인입니다.
8382 질문 전체 보기
Lines in display after short circuit / power adapter failure
Hi everyone,
my ~10y old mac (thin, non 5k) turned off out of nowhere and the fuse in our appartment was blown out too.
since pluggin it back in just caused another short circuit i went ahead, opened the display and replaced the power adapter.
after the replacement i had these two lines in my screen
https://i.imgur.com/X2vczvv.png
my question is: do i need to replace the display? i made sure the flex cable is connected properly, but maybe it broke?
kind regards
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
I'm assuming this is an iMac with a glued in display since the picture shows it running macOS Catalina. My best guess is that the display was bent or flexed a little too much when you were handling it. It's really easy to damage those displays during the removal process because even slightly bending the display can cause vertical columns of dead pixels to appear. I think at this point you would need to replace the display to fix the issue. Good luck!
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
To add to Zack’s answer, often I see this when someone didn’t use the special cutter which is part of the tape kit for the given system iMac Opening Wheel
댓글 달기
귀하의 답변을 추가하세요
Eddy 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 19
