Why does my phone charge for long
Phone charging system
좋은 질문 입니까?
@habib2927 @akshayshri55686 this can have many different reasons. First start by making sure that your charger supplies the proper voltage. Next check the charging cable. Make sure that there are no bend. broken. or corroded pins. Now focus on the charging port. A few drops of high-grade isopropyl alcohol and a few puffs of compressed air will clean out the port.
If all of this does not work, then it might be time to disassemble your phone. Think about replacing the battery as well as the USB charging port. Anything after that, will require some board level repair. For that you need to have the tools, the schematics and the experience to repair that.
해당 답변은 도움이 되었습니까?
Well I will suggest you to replace the battery of your mobile phone and keep cleaning the junk files from your phone and remove the unwanted apps which run in the background.
해당 답변은 도움이 되었습니까?
24 시간 전: 4
7일 전: 8
30일 전: 78
전체 시간: 869
댓글 1개
Charging is very late
Akshay Shrivastav 의
