주요 콘텐츠로 건너뛰기
Repair and disassembly information for the Samsung Galaxy Note20 Ultra Android smartphone. Released in August of 2020.
46 질문 전체 보기
small help for my motherboard note 20 samsung
my phone have problem black screen and touch work
iam sure the problem is backlight ic
but i dont where place on my motherboard can anybody help me
that some picture:
plate the screen:
https://guide-images.cdn.ifixit.com/igi/...
plate motherboard and some extra plate:
i just what know the place backlight ic to fix it
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @madisonjfry
I don't think that there is a separate backlight IC as such.
According to the specifications the phone has an amoled display.
Amoled displays are different to LCD displays in that the individual pixels produce their own light so separate backlighting is not necessary. The pixels are either turned on or off.
Here's a link that describes it better than I can, that may help
Update (06/06/23)
Hi @madisonjfry ,
Perhaps check if the display cable is securely connected first.
Here's the no display troubleshooting flowchart from the service manual that may help to know whether it's a display problem or a systemboard problem.
Unfortunately the manual is not quite complete as it doesn't show the location of all the components mentioned as test points. -
I only found one i.e. U10001. Here's an image of the board that it's on to show its exact location on that board.
(click on images)
Update (06/06/23)
Hi @madisonjfry
Here are the Samsung part numbers for the complete display modules for the model. It seems that there is more than one part number for the same part as searching for any of the part numbers for a variant gives the same result. Search online using the part number only to find suppliers that suit you best
Samsung Galaxy Note 20 Ultra (SM-N985F SM-N986F)
Display unit complete mystic white GH82-23622C GH82-23597C GH82-23621C GH82-23511C GH82-23599C GH82-23596C
Display unit complete mystic black GH82-23622A GH82-23597A GH82-23621A GH82-23511A GH82-23599A GH82-23596A
Display unit complete mystic bronze GH82-23622D GH82-23597D GH82-23621D GH82-23511D GH82-23599D GH82-23596D
해당 답변은 도움이 되었습니까?
점수 1
댓글 4개:
so i must replace full screen? to fix this problem?
yes all is fine connected
when the display take black i on bed watch youtube then go to black and the sound still on ( but phone very hot before screen do to black)
so i think is no problem with cable
@madisonjfry
The display is not cheap to replace so I don't know what the best option for you is.
Getting hot is not good but it could be that the display is the cause of this problem or maybe not.
Perhaps it may be better to take it to a reputable , professional authorized Samsung repairer and get it checked out. They may have compatible displays available that they can temporarily connect to find out. Also they can test the board to see if it is the problem.
any idea from where can buy screen good quality?
i check alixprees all bad quality
댓글 달기
귀하의 답변을 추가하세요
Madison J Fry 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 7
30일 전: 28
전체 시간: 209
