Why my phone is so slow and laggy?
Phone ram is very low so the phone lags and hang out easily after some task
좋은 질문 입니까?
좋은 질문 입니까?
Things to try to resolve the problem:
If it works OK when in safe mode, a downloaded app may be the cause of the problem. The trick is to find out which one. You will need to uninstall each downloaded app one by one and test the phone in normal mode between each uninstall, to check if it works OK or not. When it does the last downloaded app that was uninstalled was the culprit. A downloaded app is one that you downloaded and installed and wasn't already pre-installed on the phone when you got it.
해당 답변은 도움이 되었습니까?
24 시간 전: 1
7일 전: 2
30일 전: 25
전체 시간: 344
댓글 5개
3gb ram 32 rom phone bohut hang karta hai
HD + 의
In the upper of my phone is working but if I see the down phone had black screen If I restart restart the phone mainy times I don see anything but I will tab tab and do it
apekchha buukchhe gautam 의
Phone is very slow what's happened
hanumantha.hanu_ 의
@hanumanthahanu
Did you try what is suggested in the Most helpful Answer below?
jayeff 의
My phone screen is automatic touch
Problem
Sunita Tiwari 의
