이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 2개:
@albertgreen could be settings issue, could be a board issue. WE can't tell until you check for us. Now, we would need to know what actual model you TV is to start somewhere.
oldturkey03 의
Hi @albertgreen,
Has the TV WiFi worked OK before?
If so has anything changed, e.g. is the WiFi turned on in the home network router, has the router position changed, has the TV position changed etc.
Can other devices e.g. mobile phone, detect and connect to the WiFi network OK?
jayeff 의
