주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 A1419 / 2013년 후반형 / 3.2 & 3.4 GHz Core i5 또는 3.5 GHz Core i7 프로세서, ID iMac14,2
Internal ssd cannot be formatted
Yesterday I replaced my HDD with an SSD in my 2013 27-inch iMac. Today I went to disk utility to format the drive and install mac os and got this error. I am not sure what to do about it as there is not much information online. when I got to the info section about the drive it also revealed that I can't really do much with it. Any tips would be greatly appreciated!
cl
이미지
이미지
Here is the kit I used. it is from owc. https://www.amazon.com/gp/product/B076L1...
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
Sorry I don’t see the formatting error only the details of the drive.
You need to use Disk Utility to format the drive how did you achieve booting up your system? As a bootable MacOS drive should have the utility present within the Apps > Utility folder.
OK I guess I jumped the gun as you hadn’t posted it yet.
So what is OS version you are using here?
이 답변이 도움이 되었나요?
점수 1
댓글 4개:
I am using disk utility through the install menu. and I am installing ventura (which I know is not supported on my device, I am using open core legacy patcher to do so, which I have done before on this same exact computer and it worked fine)
의 공유
@willopillo - I would recommend you create a bootable USB thumb drive with Catalina and try the Disk Utility it offers.
I’ve seen some odd behavior with these OS patchers so I would like to rule it out first.
의 공유
Yes! Thank you! I have an old HDD with el capitan installed, booted that up and it let me format the drive, then I was able to install ventura with the patcher and it is working great!
의 공유
@willopillo - You might want to create a bootable 32GB thumb drive as I find it works better!
의 공유
댓글 달기
답변을 추가하세요
Willopillo11 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 15
전체 시간: 469
