주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Repair guides and support for televisions manufactured by Panasonic.
Turn off itself occasionally.
My plasma TV tcp55st30 occasionally turn off itself. It clicked, screen went black and the power light stayed solid red. I unplug the TV for 5 minutes, plug it in power up and worked until the next black out.
Update (07/08/23)
Update (07/08/23)
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 3개:
Can you take the back off the TV and upload a picture of the circuit boards inside? 기존 질문에 이미지 추가하기
I'll do it over the weekend.Thanks.
Sorry to take it so long to upload these images.
댓글 달기
답변 1개
@ahyong intermittent failures are the hardest to diagnose. Here is the way your TV is supposed to work (Turn ON)
IC8000 on the A board outputs the “TV_SUB_ON” command. The “TV_SUB_ON” command is provided to pin 5 of connector P6 of the power supply to develop the F15V. At this time, the relays on the power supply are triggered and a click” sound can be heard.
The F15V from the P board is applied to the Voltage regulators on the A board.
IC5000 outputs the "DCDCEN(ENABLE)" command to the voltage regulators to output several voltages respectively.
I know it's a lot of "blah blah blah" but that is the clicking you here. It sounds like it may be a component on the A-board which is failing (overheating). That would also explain why it works again after 5 minutes.
A-board is the bottom board in your last picture.
이 답변이 도움이 되었나요?
점수 0
댓글 3개:
Thanks. So I need a new or used A board. When watching certain channels, the pictures / screen become distorted. Is that the cause of overhead or bad A board?
@ahyong only on certain channels? Yes it can be but that is even harder to diagnose :-)
For now my prime suspect are the A-Board and the P-board. I'd go with the A-board first. This is not scientific, just a gut feeling. Get a replacement for as inexpensive as you can find. Used is okay because I do not want you to spend your hard earned money on my gut feeling.
Thanks again. I'll get an used A board and will update in the near future. THANKS again I really appreciate your time and input.
댓글 달기
답변을 추가하세요
Ah yong 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 4
전체 시간: 132
