주요 콘텐츠로 건너뛰기
The TI-Nspire CX handheld features a full-color, backlit screen, thin sleek design and includes TI-Nspire rechargeable battery.
Why does my cas keep running over and over again?
My case got in a bit of water and had a few minor bumps then I couldn't open it and was warned to charge the battery. I then charged it but when I turned it on it kept running and running again, I couldn't use it and there were warnings about battery and settings. What do I have to do?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
Remove the battery immediately!
I'm sorry the calculator mislead you. You should never charge or turn on a device that is wet.
The Nspire is a pain to disassemble completely. There are screws underneath the plastic screen protector where the keys are. You'll need to take a blow dryer and heat up the bezel enough that the glue weakens and lifts up the screen protector. You can see the screws here: https://tiplanet.org/forum/gallery/image...
This teardown guide should help as well: Texas Instruments TI-Nspire CX Defective Button Repair
Remove the circuit board and clean it with isopropyl alcohol. Let it dry for several hours to ensure water isn't stuck under any components.
I would recommend getting a new battery. If you're lucky the calculator will turn on and start working normally. You may need to reinstall the OS but that's not super difficult. I would recommend using the N-link website for that. You can get the latest (non-jailbreakable) OS on TI's website.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Donna 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 7
전체 시간: 183
