주요 콘텐츠로 건너뛰기
The Amazon Echo Show 2nd gen was released by Amazon in September 2018, with the model number DW84JL. To validate that your device is the same one that is featured here, check the base of the device. On the rubber pad there will be small writing with model number being included. The Echo Show 2nd Gen is a home assistant with a 10.1" touchscreen display and Alexa voice control capabilities.
Echo show 2nd gen not turning on
I have a US plug Echo show 2nd gen. A friend of mine attempted to use a UK power plug and now the device won't turn on.
Is there any way to fix it by replacing something inside the device? I think the original US power plug is still working.
Any help would be great!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @sillyzannee,
Designated chargers for the device in both the UK and the USA are the same inasmuch that their specs are the same i.e. 100-240V AC input and 15V DC 1.4A (21W) output. The only difference between them is the type of AC input plug pin arrangement making them compatible with the power outlets in the country that they were meant to be used in.
Was the UK charger compatible with the device i.e. 15V DC output? Check what its specifications are, as printed on the charger itself.
Verify that the US charger has 15V DC at the output plug of the charger, just to be sure
If the US charger tests OK and the UK charger has the incorrect specs, then the Echo would have to be opened and the motherboard checked and tested to see what damage has occurred.
If some components have been damaged i.e. burnt looking etc it may be difficult to repair as the schematic for the board would be required to know the value and type of component etc. Unfortunately I can't find one. Also I've checked for replacement motherboards but I can't find any either. You may have better luck.
Here's the ifixit Amazon Echo Show 2nd Gen Motherboard Replacement guide that shows how to open the device to gain access to the motherboard.
If you see some damage or you're not quite sure, post some close up images of the motherboard in your question. Here's how on ifixit 기존 질문에 이미지 추가하기
iFixit 이미지
안내서
기존 질문에 이미지 추가하기
난이도:
매우 쉬움
2 - 5 minutes
Amazon Echo Show 2nd Gen Motherboard 이미지
안내서
난이도:
조정
30 minutes
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
SilLyzanne e 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 15
전체 시간: 256
