주요 콘텐츠로 건너뛰기
Repair and Disassembly guide for the 2020 ASUS G15 G512LI, A laptop produced by Asus for budget/light gaming.
Won’t power on
My pc won’t turn on I got it last year and left it in my closet because I try turn it on but the power button won’t show up and there supposed to be a light on the charger but it doesn’t show it is it because my charger connected maybe out of use because I did get it a year ago
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
@erichills54272 your charger should not quit working just because you haven't used it. Your laptops battery may have. It may have been discharged below it's threshold to accept a charge. Consider replacing that. Check your charger to make sure it outputs the proper voltage. Check the charging cable for any send or broken connectors. Check the charging port for any debris, broken or bend pin. You can always clean it with a few drops of isopropyl alcohol and a few puffs of compressed air. If it still does not come on, time to check it on the inside. Since you are probably going to replace the battery, use that opportunity to double check the DC in jack for proper voltage on the board side.
Use something like this video as your guide.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Look for any LED lights or indicators on your PC that should normally illuminate when it's powered on. If you don't see any lights or hear any sounds, it could indicate a more significant hardware problem.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Eric Hills 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 11
전체 시간: 466
