주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Computer won't turn on
Charging port was loose and after watching a video I soldered the loose port hoping it would give a good connection. Now I don't get a green light when plugging the charging cord into the port and the computer will not come on. Tested continuity on charger and that is good, tested on charging port and got nothing. So I'm not sure if the port is bad or the motherboard. Not sure what else to test. I purchased this computer in Nov. of 2021
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
Hello
Take a look at the steps needed to find a short circuit with a multimeter
Check inside the charging port for any obvious unsafe conditions,
such as short circuit betwen positive and negative connector.
이미지
You have to touch the black probe multimeter to the negative and the red probe to the positive chargir port.
if you are seeing a value of 1 or OL, then there is a short circuit in your electrical circuit.
clean your solder with a solder wick and do the test again with a multimeter, is it still short or not
if you seing a certain resistance value other than OL, means your charging port has no problem,
the problem is other part on motherboard
Send it to a professional to get service handling assistance.
good luck
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Dell 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 13
전체 시간: 337
