주요 콘텐츠로 건너뛰기
Unveiled at the 2000 North American International Auto Show on January 10, 2000, the redesigned 2001 Dodge Caravan and 2001 Chrysler Town & Country were released for sale in August 2000.
Will Not Start after it ran rough
Started the 2007 Caravan the other day, only has 15k on it. it started, ran really rough then died. Now it will not start.
Have checked all fuses, used a OBDII scanner and there were no DTC's, Checked for spark, that's good, I can hear fuel pump fire up when I turn the key on.
I am puzzled.
I know it has to be simple.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
Brian, just to clarify, it is turning over when you try to start it? Automatic or standard transmission?
yes it's turning over just won't start. Automatic trans
댓글 달기
답변 1개
선택된 해법
Brian, try to disconnect the air intake hose from the throttle body and shoot some starting fluid in, then try to start it. If it fires up and runs only to die out, there is a fuel delivery issue. You might also have to check the Crank sensor and Cam sensor, though make sure the relays under hood are working. When you first turn on key,not start, just on, you should hear the relays click.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
답변을 추가하세요
Brian 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 765
