주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Razer Blade 15" Base Model (2020)은 10세대 6코어 5.0 GHz Intel 프로세서를 탑재한 강력한 게이밍 노트북입니다.
Adding USB-C charging option externally
I've seen some adapters around that connect to Razer's proprietary connector, and was wondering if anyone has attempted to use a USB-C PD board to charge the laptop? I mostly use my laptop portably in Linux without use of the discrete graphics so I only require <100W of power which USB-C can provide. But unsure whether the charging port will accept less than the 230W that comes from the regular charger
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
Would love an update on this!
의
댓글 달기
답변 1개
@lachlanhogan It depends how razer has their power management set up, with other brands such as Dell they force the CPU to throttle a huge amount if it's not connected to the correct power supply, either you'll get lucky or it won't be usable unfortunately.
Thanks! :)
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Lachlan Hogan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 30
전체 시간: 1,121
