주요 콘텐츠로 건너뛰기
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
20 질문 전체 보기
Why does my pc not show image on my screen
Basically, my screen turns on, my pc turns on but i see on the screen "standby mode" i ve made sure the hdmi is connected, but i dont know why it does not show image on the screen
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개:
Hi @mariusbuduca,
What is the make and model number of the motherboard?
Can you get into BIOS with a display?
Can you try another monitor e.g. TV if you're using HDMI?
Are you sure that the PC is booting into the OS i.e. if Windows, do you hear the welcome sound (if enabled)?
What have you tried?
Motherboard is A320-M PRO, no i cannot get into bios with display, didnt try the hdmi to another monitor or tv, i never heard the pc booting in the os sound since i ve had the pc
I tried replugging ram/hdd/m2
Tried unplugging the ventilator and also tried with a remote desktop on my phone from an app and i ve seen my apps and all that i have on the pc but on my phones screen. Can it be a monitor problem?
댓글 달기
답변 1개
Hi @mariusbuduca
Since you get images from your PC remotely, this proves that it is passing POST and the PC appears to be booting into the OS OK, so it could also be a GPU problem (assuming there is a separate GPU card installed).
What is the make and model number of the CPU? Does it have integrated graphics?
If it does, remove the GPU card, connect the monitor to the motherboard's HDMI port and check if you can get a display in BIOS. You may get a display in Windows but it may only be basic drivers loaded and not specific for the integrated GPU.
If it works at least you know it's the GPU card and not the monitor or HDMI cable.
If the CPU doesn't have integrated graphics then you may have to try a different known working monitor (TV?) and HDMI cable and if still no good then it's the GPU card. If it works then you know it is the monitor or HDMI cable. You will have to try each one again to know which it is.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Marius Buduca 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 47
