주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to replace keyboard surrounding plastic?
In life as a college student, laptops are not always the luckiest. I'm looking to replace the keyboard's surrounding plastic as it's badly cracked. I think it is called upper housing.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @bookworm3616
To replace the top cover, you have to completely disassemble the laptop.
Also getting just the top cover replacement part and not the complete top cover/keyboard assembly may be hard as it comes as one complete module.
Not totally sure re this model but with a lot of other HP models (different series) the keyboard is "riveted" to the top cover by nylon type plugs, so if you do find a top cover minus the keyboard, you may be able to remove the keyboard in your laptop by either snipping off the plugs or melting them with a soldering iron or similar and then gluing (epoxy?) your keyboard back into the new top cover
Here's the maintenance and service guide, taken from this support webpage for the laptop.
Go to p.65 to find the part numbers for the various top cover/keyboards used in the model series and also the country specific suffixes required to amend the top cover/keyboard part number to suit your location.
Note that the top cover with keyboard information is at the very end of the Component Replacement Procedures i.e. complete disassembly.
Search online using the appropriate to your particular model variant top cover/keyboard part number only to find suppliers that suit you best.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Bookworm 3616 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 27
전체 시간: 357
