주요 콘텐츠로 건너뛰기
Repair guides and support for Whirlpool brand dryers.
dryer igniter not working.model#WGD8300SWI
error code#29--replaced moisture sensor,fuse ,exhaust thermistor,coils,igniter,and control board sensor circuit. what the f is next?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
Hi @wayne1396
If you haven't got it already here's the tech sheet for the dryer.
Seems as though you've replaced everything mentioned for a 29 error code but if you haven't done so already, perhaps run through the test #4 on p.12 and then test #3a on p.10 (if necessary) as described in the sheet and check.
In the end it may be something else on the control board not working, that is connected to the control board sensor circuit which in itself may be working OK.
There is also a wiring diagram on p.4 so you can check the wiring from the control board, right through to the ignitor
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
WAYNE 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 4
전체 시간: 149
