주요 콘텐츠로 건너뛰기
2012년 6월 출시 / Core i7 프로세서 Turbo Boost 포함 / 최대 1 GB DDR5 비디오 RAM
MacBook Pro 2012 not powering on
MacBook Pro 2012 is not booting at all. The charging light is green when connected, however the fans don't spin, there is no chime, and the drive does not spin.
  • Reset of SMC and NVRAM
  • Held power button for 30+ seconds with / without power / battery plugged into logic board
  • Removing all connections from the logic board, and testing each component while trying to turn on
  • The internal components/logic board appear clean and undamaged
  • Check power button cable - all fine
  • No liquid damage / all water spots are untouched
The last thing I could try would be to ensure the board is receiving power with a multimeter, I have one but have no idea where to put the connections for testing.
Any suggestions would be appreciated.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
I'm not sure if you did this: disconnect the battery and the mag-safe, press and hold the power on button for 15 seconds. Now reconnect the battery then the mag-safe. You should get a spontaneous reboot.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
StuartM 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 8
전체 시간: 130
