주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung은 2023년 2월 1일 “Unpacked/언팩트” 행사에서 Galaxy S23 라인업을 발표했습니다. 새로운 Galaxy Book3 및 Galaxy Book3 Pro 시리즈 노트북도 발표되었습니다.
I think my charging port is loose or bad or dirty.
My phone frequently disconnects from the charging cable/Android auto I've tried new cables and it still happens. I have to unplug and plug it back in to reconnect, but if the cord moves a little bit, it disconnects again.
So I think it's an issue with my port on the phone.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 달기
답변 4개
선택된 해법
@adamtomesh While usually I'd recommend replacing the charging port, chances are your phone is still under warranty since the s23 ultra is a fairly new model.
If it is, please take it in to get a replacement port since they will ensure the phone is properly resealed against water ingress, which you can't guarantee if you perform this repair yourself.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Was able to get a "like new" replacement phone for free. Which I figured was the best option rather than having me or a local store repair this one and hope it's done correctly.
solution was--
first connect your charger then wait wait 20% charge complete then ( when you do these 6 step dont unplug your cabel complete these 6 step
1- clear datae usb setting
2- clear data android system
3- clear data anroid system (when search android system then 2 android system show clear both of this)
4-cleader data device care
5- clear data one ui home ( its main)
6- then restart you phone
unplug you cabel and wait 1 hours for rest your phone then cheak your problem was gone
댓글 달기
가장 유용한 답변
it is very likely that there is a problem due to the dirt accumulated in the connector. you can with tweezers (only one side) taking care not to cause shorts, clean the dirt first. you can use a small brush and compressed air to clean the connector completely.
if the problem persists you must check the sakdature of the connector or if the seat where the cable enters has been striped and if it is tightening it to size
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
I did buy a cleaning kit with tiny brushes to clean dirt out of there and got some dirt out. but it didn't really change after.
I believe it's tightening when it goes in because it feels pretty secure.
I took that problem to Best Buy and the geek squad guy said he shredded a tooth pick into a brush and cleaned it out and it is good as new.
I tried to clean with a toothpick at home and this worked for me! If you shine a light down the port you should see silver metal on the inside, not black. The black is grime.
댓글 달기
@adamtomesh since cleaning does not resolve the issue, I would suggest to replace the charging board. Those boards are widely available and luckily not to costly. Just remember that you will need one that is for your exact model. Check on sites like this for an idea of what you are looking at. This is not an endorsement of the seller, just an example. To replace it, use something like this guide It is in French but browsers like Google Chrome translate these almost perfectly.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I had this exact same issue on my S23 Ultra, with USB Charging and Android Auto disconnecting so often both were unusable. Cleaning didn't fix it, and I called Samsung to figure out what to do.
They suggested to wipe the cache partition.
I scoffed at the idea, since the issues I was seeing seemed like an obvious hardware issue, but tried it anyway. Much to my chagrin it actually worked, and I haven't had any issues with USB charging or Android Auto disconnects for months now.
To do it, shut down your phone. Then hold Power + Volume Up until it brings up the Android Recovery menu. Use the volume keys to go down to Wipe Cache Partition, then press power to select it. You'll still have all your apps, data, etc and it's a whole lot faster and cheaper than trying to replace boards or send it back for a replacement.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
I have same phone same problem your fix worked thanks!
Didn't work for me...tried twice & really had my hopes up as I don't relish replacement, etc!
댓글 달기
답변을 추가하세요
Adam Tomesh 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 21
지난 7일: 142
지난 30일: 703
전체 시간: 47,521
